Did it get that high!? When I checked my watch (apple) the highest I ever saw was 86. Which is certainly warmer, but for us southern flatlanders isn't too out of the question -- though maybe ocbober it is a little uncommon. There's been a couple times this year that we've had to run the furnace and the AC on the same day....
@Ken & Peggy, thanks for the contact.
BTW --- my house is in the middle of the eclipse path --- I don't think I have to go anywhere to see it. Lake Monroe State Park is probably your best bet unless you get on the RV pads near the entrance at brown. It looks like MAYBE summit lake may be a good spot too, its over near New Castle. Not a bad park, but in the 'tree lined' part of the campground it tends to be moist....
Do you know where there is a better map that may be interactive or where you plot a lat/long to see the percentage and duration?
Do you know if the Apple watch gets its temp from measuring it directly, or if it gets it from a nearby recognized weather reporting station? The reason I ask, is that I've seen significant changes in small distances on my cars outside temp display, like when driving home on the township road seeing 90 degrees on the display, but after turning down our 1/4 mile heavily wooded driveway, I will often see a 4-6 degree drop by the time I reach the house.
