2025 Toyota Land Cruiser 250
We own a 2024 Toyota Land Cruiser (“Elsie”) and prior to buying #1010, we rented a couple of other bigger travel trailers (Rpod and a Jayco - Sorry….I can’t recall the weight of these) and it towed just fine. But with our 560 we can sometimes forget it’s back there.
Mileage on flat interstates is about 20 mpg towing our 560.
Everything on ours is stock. It’s comfortable to travel in but it does have limited storage in driver/passenger area. We love the 2400W inverter. We’re running an Iceco fridge and a EcoFlow in the cargo area from the AC outlet. Makes it all so simple to keep things running and charged.
It does have a small gas tank. Just 17.9 gallons. It says premium fuel is a must. Could be because it’s a turbo. Gets about 22-23 on highway without a trailer attached. I’d say we get 17-18 city. Hp=326… torque is 465.
If you go on the LC forum people will be complaining about gas tank size and need for premium fuel. Many people I’m sure are using regular unleaded but I’m going with premium, at least until the warranty is up.
We’ve had it for a year now and are proud owners. Happy to answer any other questions.
The 26 Rav4 has doubled its towing capacity from 1750 to 3500. Will be seriously looking at it once in the show room.
Thats a fine vehicle too. For anyone who is into accessorizing their vehicle for more off-roadish capability, the RAV4 is second only to Subaru who has been doing kewl stuff with LP Adventure...bumper light mounts, bambi bars, skid plates etc (@Jenn ) to replace the fragile plastic dust covers...
I'd look closely at RAVs except I want to move up from AWD (which is fine for 90% of where you might tow the CI) softroading...
To actual 4x4 for more confidence when solo self rescue. Be nice to mount a winch too, which will would pull my Alltrack pull my radiator and intercooler right off off at bumper mount on unibody...
So, you need a body on frame construction...like 4runners, Tacos, LCs, Rangers, Jeeps, Big Bronco, etc.
I realllly like the trucklets- Maverik especially but you just cant crawl slow enough to tow on rutted rocky fire roads or thru sandy washes even aired down in AWD gearing meant for mpg, to get to the amazing places away from the crowds, in the western lands.
So I am looking for 4x4 with lo-lo, locking diffs
Ya imho thats pretty good MPG for that size vehicle and engine pushing whats basically a small barn door like any other SUV or truck.
Nice thing is the CI is aerodynamically in the wind shadow as much as possible so thats a good match.
17 gal? I'm at 14 in Alltrack with same mog fulky losded towing, so ya I'f like more too.
Its plenty to get in and out most places if you plan ahead but it would be nice to carry a liitle extra as an "oops" backup. Plus for those long stretches in between... sometimes the gas station on the apple map or goolag is no longer there, or closed early...
Or to run a genny if you needed it to recharge CI battery, run dometic plus other toys that SUCK POWAH like Starlink...if you were going long somewhere with not enough sun.
I'm trying to figure out how to hang a couple of those flat tanks off of my TV
Or mounted on the CI but really prefer not to add more weight to CI if I can help it. I've tried carrying 2 5 gal jugs on the Iup cargo rack attacked to bike rack on the CI bumper mount but thsts pushing the weight limit and I only fill up on the last gas station before boondocking- as the center of gravity and "moment of sway" gets a little sketchy at speed...Others have done better putting them on TV bumper, but I'm limited out on that by Alltrack hitch mount limits, 1up rack geometry...still noodling...
I imagine plenty of people have done house batt-trees inside LCs and a couple here have done kewl stuff in vans and trucks,
but like you I like to keep the cargo area flexible, and
For me the wiring simple, cuz in my case I have to open the link Sweeney sent me to basics like Ohms Law and how to use a voltmeter every time...
so my DIY on EE is suspect...;)
Three things I forgot to add about towing with LC.
1.) The towing tech is not very user friendly. There are several safety features you have to manually disable when really, if you push the tow mode button, that should be done for you imho.
2.) The 7pin connector is right next to the exhaust, so… it’s annoying.
3.) There aren’t any after market mirror extensions that fit on the LC blocky mirrors. This was very problematic (dangerous) when we tried those larger trailers. Hated that. There are companies that list their universal mirrors as fitting the LC 250 but they don’t. With the 560 rear visibility is not an issue.
TY. Good info.
I'm assuming automatic trans?
Does yours have a separate trans cooler, or an option to add later?
TY. Good info.
No standard separate cooler that I’m aware of. Have not looked into that but then again, after we ended up on a terribly steep grade, having chosen the wrong road to our destination, and watching the temp gauge shoot up, I’m motivated to do more research…
EDIT: I just want to add that my transmission was getting “heated” on a very long, rugged, steep grade, unpaved road. We had no business pulling our trailer up that hill. Normal towing conditions, on paved roadways, pulling a heavier trailer than our CI, on hilly stretches of the Pacific Coast Highway, it did great.
The latest Motortrend article on the RAV4 was very good. Definitely a consideration for me if I could get the wife to sell our Escape 21C. My 2023 RAM etorque died with no warning recently. It doesn’t have a traditional alternator. It has a Motor Generator Unit and a 48 volt battery which powers the auto/stop feature instead of the 12 volt battery under the hood. Parts availability has been an issue getting a MGU or 48 volt battery.
Sorry to hear that -- this is my biggest thign I fret over -- the only caveat is I have a toryota and they have been in the hybrid market a long time and seem to have it figured out. Perfect? No. I love my Rav4 though it is not adequate as a tow vehicle of any kind, unless they've upgraded the brakes and motor a bit - mine struggled with the rolling hills of wisconsin, as I am sure it would in northern florida. Tenneesee? Never tried it.
Curious what year your hybrid is. Mine is 2017. While I don't do a lot of mountain towing I definitely do have to go through the Grapevine or the Cajon Pass, out and back on every trip anywhere as well as routine gradients just getting from A to B. While it isn't what I would call powerful it is definitely more than adequate. It's rated for 1750lb towing.
The newly redesigned 26 Rav4 has a towing capacity of 3500 lbs and 236 HP. My old one only makes about 192 HP. So I would have no doubt or concerns about a new Rav being able to tow any CI.
Oh, and not too long ago, at 96k miles, I finally had to replace my front brake pads for the first time. The rears still measure about half worn. IMO, it's hard to go wrong with a Toyota hybrid.
Yup. Toyota for the win on anything hybrid.
See Prius.
They have been at it the longest and have enough units on the road and dealership network or indy mechanics who can work on toyota, fair prices on parts all over the country.
If I were doing AWD with hybrid and some extra clearance for "soft roading" I wouldnt bother looking elsewhere, just for peace of mind.
Plus there are after market makers of kewl semi off roading stuff long supporting Subaru that also make stuff for RAVs. Light bars, skid plates.
If you want 4x4 then its Toyota Tacoma or Jeep Wrangler for the win.
Anyone tow with a Land Cruiser like the new one?
Any early learnings, towing observations, tips?
I towed with an FJ Cruiser, then a 4Runner. I just got a Lexus GX 550. Haven’t towed with yet. It was between the Land Cruiser (awesome choice too) and the GX 550. I can say that whereas my 4Runner hitch had a 2.5” or 3” drop, looks like the GX requires a 6” drop. Not sure about what the Land Cruiser needs.
Hey David, good to hear from you- mentioned a day ago you by way of good solar advice to me, and example with genny as a back up.
Any long trips lately? Whats your setup with gear and powah in the TV?
New or used?
Customizing the lexus 4x4 SUV is a off roaders "thing" here in SoCal.
I've done 3-4 trips to Nova Scotia from California over the past several summers. In 2023 I left June 25 and drove to the Arctic Ocean on the Dempster Highway. I left my 560 in Dawson City and car camped on the Dempster. The Dempster would have been too hard on the trailer. Then drove across Canada to Nova Scotia. Spent a month (August) at the family cottage, then drove back to California. It was a 15K mile road trip. I guess that qualifies as long! I have a 2026 560 being built at the Mother Ship right now. Going to sell the 2020 when I take delivery.
Hard core! Love it!
Whats your plan for powah on the new one?
