Questions & thoughts on power
taranis17
(Channels inner Tim Taylor - augh augh augh....)
Maybe I'm getting a bit ahead of myself, given that I don't yet have a 560 in the garage yet, but I've been considering how best to outfit the rig for extended off-grid camping. 3-5-7 days max off-grid, then charge up for a few days (and get a hot shower), before moving on.
Options abound (power stations, types of solar panels, LifePO4 batteries, et al.) as well as opinion on what's "best." Since I work-from-home, I can also work from the road. A Starlink Mini is an absolute requirement, as is at least some Air Conditioning (what can I say, I'm a sensitive, delicate Texas flower that sweats like it's raining outside) and the ability to charge a Macbook and iPhone. An ice-maker would be nice too but I can cope.
Anyway, I'm considering a Bluetti Apex 300 system along with two 350w solar panels + perhaps a DC-DC charger or a Honda eu2200i generator (side question: will this be enough to kick over the AC compressor?).
The overall idea: plug the trailer into the power station and slow power drain/usage with 700w of solar input - basically stretch my usage out for 3-5 days of normal usage. I can also add additional batteries to the main unit if I find it falls short by itself.
The one bummer in this plan is the AC air conditioning - converting from DC->AC will hurt, not to mention aircon will be the biggest draw by far. Thinking about it more, I'm also going to lose on DC>AC>DC conversion charging a phone/laptop through the trailer vs charging directly from the Bluetti itself. Not insurmountable but... Hmm....
How would you guys do this? Or do I just have unrealistic expectations. I'm a sponge willing to learn....
I think you should call Cary and run all this by him. You have some mighty big plans. Find out for sure what is or isn't physically possible trailer wise before investing in anything.
All else apart, there’s some homework to do to even approach this question:
1. Determine power draw of all loads and their average use hours per day.
2. Do the math, resulting in watt-hours or amp-hours per day each load. Add them all up.
3. I don’t think anyone has figured out a way to stuff more than a 100ah battery in the CI battery compartment. Lithium is better for extended off-grid use because you can draw down 90%+ of its capacity, unlike lead acid deep cycle where drawing down more than 50 to 65% (depending on the battery) is going to shorten its lifespan, perhaps radically.
3a. How many days or hours will you get out of your “house” battery?
4. Now you can look at capacities of pony batteries and power stations aka sogens.
5. Now you can look at charging systems, including generators and solar panels. Open sunshine where you camp. Etc.
Highly recommended: the CTEK DC-DC charger/solar controller. The best way to shorten charging time AND extend the life of your house battery.
I didn’t see a refrigerator in your uses. It’s going to be plugged in 24/7 unless you have ready access to ice.
Putting all this info and formulas on a spreadsheet is really the best way to make sure you’ve got it all, your calculations are correct, and you can easily run alternative approaches while you’re figuring this out!
Dang it! Forgot about the fridge. Yes, this is a good place to start. Thanks for your post!
Welp, I might have some unrealistic expectations, especially with that AC unit. Looking north of 4000-4500 Wh capacity needed.
Feel free to check my math.
Some givens:
- +20% derived from Wh total for unexpected draw and AC/DC conversion loss.
- Usage for DC components are averaged, while AC (air conditioning) is estimated high.
Two problems I see: Storage capacity and necessary solar input. If we go with two days of battery autonomy (no solar) that puts storage at 1000+ Ah, and with average daylight of 5hrs/day, I would probably need three 350 watt panels to recharge from 20% and still have usable power.
Too. Much. Money.
Looks like a hybrid setup would be the most cost-efficient - one or two 350w panels + 2000w generator for bad weather days.
(Sorry if this has been talked to death on here.)
Within the General Topic there is a thread…. About those Solar Generators.. good read
Bit of a wait till the Xmas deals but at least you have time to do some homework. :)
The EU220i does fine -- it will start the compressor even in eco mode --- but it does 'burp' which I find bothersome. I run mine on 'non-eco' and it is just fine.
You're definately a power user -- like me. More pawah! The onboard batteries are great for lights, maybe a portable fridge, and a mobile phone or two. Add a solar panel (or factory option) and a lithium batter and you'll be in even better shape. Starlink too is abig power draw...60 watts. for short-term use -- using it for an hour or two then turning it off you'd probably be ok too with the solar/litium setup...
The lithiums are great becuase they charge so fast...a lot more efficient than lead acid...
