Sweeney
Administrator
Thats two for me!
Word to the wise -- Check your batteries when your unit is in storage, ensure the charger is working. The on board electronics (USB Chargers, Radio, computers) all account for what is called "parasitic draw" -- just pieces which are on "standby" waiting to turn on.
I noticed a couple days ago my GPS Spot Tracker was reporting "On battery" instead of its "voltage" report. After finding time to check it today, I discovered the extension cord plugged into the trailer had gotten unplugged at the wall. The parasitic draw discharged the battery....completely. Not even enough voltage to make a light glow dimly, or the 12 volt meter wake up, or the slightest glow from light bulbs.
The hard part is that the on-board charger requires some voltage to detect the presence of the battery. Once I plugged back into the wall no lights came on. The charger couldn't see the battery, so it never produced a charging voltage. To remedy this, you need to apply 12 volts to the battery posts -- THEN plug in the charger. It will see the voltage, and begin charging the battery. To accomplish this, I used a very old 2/6 amp charger that was given to me for Christmas when I was a teenager. Yup....still works like new. I set it up for a 2 amp charge rate at 12 volts, and connected it directly to the battery for a few minutes. Then, I plugged in the shore power, the on-board charger saw 12 volts and been sending power to the battery.
We'll hopefully it charges - otherwise its looking for a new Group24 battery.
Check your power folks.
