My research showed the average run for a Dometic to be 2.5 - 3 amps averaged at 25 degrees C for a daily high. Compressor time was over 5 amps. I wondered if the 45 watts was an average figure, although it should be closer to 33 watts.
Babble - I found the smaller storage compartment in the 550 under the mattress will hold 8 1/3 gallons of water unless you put something in it.
