Tire Recommendations
In the past, I've seen discount tire and other shops installing tires brought in by customers. Check with them - if you're lucky enough to have a small independant mechanic, they will usually do it too.
I bought the tires only from Walmart. They delivered them to my house. I took the wheels (alloy) off my 560 and took them one at a time to Walmart to have the new tires installed. Very easy process.
If you want Walmart to install them for you be aware you must buy the tires from Walmart. They can be delivered to your house or the store. Don't remember what I paid for installation but it was very reasonable (including balancing).
Thanks JohnC
We are replacing our camper tires and are looking for recommendations on what type of thread sealer (if any) to use on the lug nut posts?
Hello Community! We just acquired #1010, a 2020 560 Ultra. We do not have a lot of confidence in the tires (the trailer was stored outside) and are looking for some tire recommendations. We have the Aluminum Alloy rims.
Allen
I replaced mine with same as factory. Lucky that my local guy had in stock. Tires really only last about 6-7 years regardless of wear. Rubber deteriorates while sitting still…
I see now that I never updated this post with my selection. We went with the Carlisle Radial Trail HD. Wanted fresh rubber before going on our first trip. We’ve been out three times, the wheels stayed on, and looking forward to more adventures in ‘26.
