Sweeney
Administrator
No, no --- I talked about a transporter to make it easier to see friends....YOU mentioned a hot tub, which is where everyone became all twitterpated.The teleporter option for the CampInn should only be offered after the hot tub, which I hear is close, very close.
BUT SERIOUSLY!
I've temporarily removed the banner notification. This issue might resurface around January 1st, and I'll be keeping an eye on it.
You can check the certificate's status yourself. In most browsers (I recommend Brave), look for a small square icon with two sliders to the left of the URL bar. Click it, then select 'Connection is secure.' This will show whether the certificate is valid, along with details like validity dates. Most of this info is only relevant when there's an issue.
In Safari, go to the website, then find 'Connection Security Details' in the menu bar at the top to view the certificate in a pop-up dialog.
You _can_ override the warning screen, but don't do it. If you see a certificate warning, the probably is that it is a configuration problem, or huaman error (or worse, AI errror.) This certificate stuff helps ensure you are communicating with the correct server and games aren't afoot. Craig and I will have to have a come-apart conversation with Godaddy if this repeats.
