Hmmmm... I thought this excellent thread had pretty much played itself out, but now I just can't help myself. I have to add a question Evan's note brings up.
"[P]lug it in to an outlet when you store at home...."
Evan, how are these things wired? Are you saying the 12v system rides on the 110 system whenever it's plugged in? That would certainly make sense, I'd imagine. I would then further imagine that whenever it's on shore power it's trickle-charging, and thus your note? Is there a good voltage limiter/regulator/whatever included, then, to ensure it doesn't overcharge? (Ignore my faulty nomenclature here -- I became a CE because I didn't understand EE more than forty-five years ago).
According to the wiki article on lead-acid batteries (http://en.wikipedia.org/wiki/Lead-acid_battery), overcharging is very damaging: "3.Precise float voltage (±0.05 V) is critical to longevity; insufficient voltage (causes sulfation) which is almost as detrimental as excessive voltage (causing corrosion and electrolyte loss)." And even without the article to tell us, we techies all know about and have seen electrolysis at work, the hydrogen and oxygen bubbles coming off, etc., depleting the water and producing explosive gas.
I know the electrical power aspect of RV/trailering is a mature technology, so these things have all been worked out many years ago. But how is this particular 110/12-volt connection set up, and is months-long storage plugged in to shore power really the safe and recommended course?
(And an unrelated comment on the thread: Voltage reading is also dependent on temperature, the standard reading being at 68 degrees. If the battery is hotter or colder (from weather, or from recent load or charging), your voltage reading may vary).
