Lithium Battery BMS Behavior
Sweeney
Administrator
Yup - I did it. After I killed my high end deep cycle battery, I jumped into the pool of lithium batteries. Mostly becuase of cost savings -- it was less expensive and a BMS would keep me from being dumb for the 4'th time. This combined was enough to push me over the top and entice me to jump into lithium batteries for the first time. The cost is lower (finally) and the apparent problems of cold charging are resolved, and finally there is just the overall "on paper" improvements that I still need to be convinced of.
The battery I purchased was a Li Time Battery - I would have rathered follow the nest in their brand selection, but I needed one faster than I could get one so I went with Li Time. I upgraded my onboard charger a couple years ago, going from the standard at the time 5amp charger to a 10. I also have the Victron Smart Shunt
Observation and Questions:
ONE:​
The victron controller (The Smart Shunt) using the same settings as for lead acid is wildly off from the battery BMS. Like huge differences. I have adjusted parameters suggested by technical documentation - we'll see if this improves it. How does yours compare with the battery BMS if you have one?
TWO:​
The 10 amp onboard charger falls of in amperage as the battery gets fuller. The BMS on the battery drops into 'standby' when it amperage gets down to the 2 amps range. The BMS has 3 modes: Charging, Discharging and Standby. Once it goes into standby, the only way I can 'push' the charge higher to attach a 50 amp converter (from the RV service truck) to put it back into charging mode to get it up to 100% --- The onboard 'stalls out' at around 80% SOC. I need to verify this number. This is fine for testing, but surely something that is not a great solution. For batteyr longjevity thi smight be a plus, and it still gives me a geater Ah capacity than lead acid.
I just charged to 100%, and am now 'running down' the battery by running lights without the onboard charger, simulating a trip I am hoping to make next week.
THREE:​
Once I reach 'discharging' status -- I am not sure when the battery will again request charge - I assume it will oscilate between low and high range. I am curious how this will work in the world.
What I mean by that is si, if I am charging with solar (or shore power) and the battery decides at 8am its done charging, and my refrigerator pulls it down to 40%. There a chance or likelyhood that I'll now run out over power overnight. I wonder if the behavior on 'solar' is different -- if the solar charge controller kicks up 8-10 amps at "sunrise" will the battery respond differently than being on shore power. Will I just need to power cycle the charger at waking?
This is why I love this forum - I'm sure somone is going to answer this without the typical internet snark!!! Oh crap, I just set up for snarky answers.
ONE:​
TWO:​
THREE:​
I’ll try to contribute with my limited knowledge in what I have observed with my 560. Every time, solar will take my lithium battery to 100%. On AC power, the charger will initially kick in but will quickly terminate charging if the lithium battery is over 85% to 88% charge. The charger will start charging again when the battery gets down in the upper 70% to lower 80% of charge. But it rarely will take it back to 100%. While hooked up to my tow vehicle, I seem to experience good charging.
TWO:
Following with interest!
Regarding #2 above, a few years ago I bought a 50ah Li Time (pre BMS) to serve as my “pony” CPAP battery. It’s gotten me through many nights of off grid camping and a few power outages at home - absolutely great results.
My 10a Victron charger’s lithium profile did NOT match what L-T docs said!
I emailed L-T, possibly through their web site or perhaps Amazon mfr support link and got clarification on best charging for the battery. I was very pleased with their customer service, and set up a custom profile on the charger that I use to this day.
So that’s my recommendation; the documentation that came with your battery may be outdated due to firmware update, (or maybe there’s new firmware? Is it updatable?), or manufacturing defect…
It’s worth an email to Li Time!
I have some limited knowledge just based on my own lithium research:
1. Does your charger specifically support LIfePO4 batteries? The charging profile for LifePO4 is different from lead-acid. At one point I looked at upgrading my previous camper to lithium from lead-acid, and was told I also needed a newer charger that supported lithium battery charging.
2. Have you synchronized the Vitron Smartshunt to the battery after the battery has been fully changed to 100%? (Tap Synchronize SOC to 100% in the app)
3. Have you reached out to the LI-Time manufacturer and asked them the proper config for your Vitron smartshunt?
Research shows these settings for a LI-Time LifePO4 battery on a Vitron Smartshunt, but I would verify with them:
SettingRecommended
Battery CapacityYour battery Ah rating (ex: 100Ah, 230Ah, etc.)
Charged Voltage14.2V
Tail Current4%
Peukert Exponent1.05
Charge Efficiency99%
Current Threshold0.10A
Time-to-go averaging3 min
Reading what you said about your charger, it seems like it does not support a lithium charging profile, which is why you're seeing the battery get to ~80%, then dropping too early to the "float" charge profile. Lithium voltage behaves differently, which is why that happens. If you're using a non-lithium charger, you also risk inadvertently activating a "Desulfation/equalization mode" that many lead-acid-only chargers have that briefly pushes the voltage too high (15v+) trying to equalize the charge across what it "thinks" are lead-acid cells, which you don't have and lithium batteries don't like.
I'd strongly recommend reaching out to both the charger manufacturer and LI-Time and go over your configuration. I'm happy to be wrong on any of this - no ego here. :)
Most LiFePO4 batteries can be monitored from a phone APP. In addition to percent charged, storage voltage, change in each cell bank, and balance on the APP, there is the ability to turn off the discharge mode and charging mode from your phone. During winter storage or any time the trailer is not in use, I turn these modes (especially the discharge) to off. Yes, you have a master switch to isolate the battery, but if you turn off the discharge mode an electrical meter will not pick up any voltage when touching the battery terminals. The is a better solution to ensure no parasitic electrical drain.
I live in Phoenix where the temperatures rarely go before 32F, but I finally checked on my trailer a week ago after having being outdoors in storage since December. I parked it with 100% storage and the battery is still at 100% at 13.3 volts. This is the most "peace of mind" I have ever experienced with a 12V battery.
I had Craig, Carey, and company install the LiFePO4 battery last summer when at the Mother Ship. My 560 is a 2015 model, which is the year before CampInn modified the battery compartment to accommodate the Lithium option with minimal effort. Best decision so far. I am not a lithium guru.
Edit: Remember to turn on the discharge mode from your phone during a trip with the trailer, or you'll be scratching your head why the fantastic fan doesn't have power.
... but I finally checked on my trailer a week ago after having being outdoors in storage since December. I parked it with 100% storage and the battery is still at 100% at 13.3 volts. This is the most "peace of mind" I have ever experienced with a 12V battery.
FWIW The manufacturer of the LiFePo4 batteries we have recommend that when you are storing the batteries for long periods, that they be charged only to about 60% before storing, which is what we do with our EcoFlow sogen units, and bike batteries when we head to the southwest during the winter months.
Can you share the victron charger settings that you are using? I purchased a LiTime group 24 (heated) and am not happy with the way the new victron charger works. The lithium battery setting in the charger does not fully charge the battery. Last fall I had played around with the custom settings, but not sure I got to where I wanted to be.
OK -- I havn't attempted to attach my solar panel, but my charger seems to have the same results as your. I suspect its the charing profile on the onboard -- I think it is still ramping down its output for some reason? But at least I'm in the same situation...
I'll do that -- I have most of the specs in the manual that came with the battery, excpet the phukette (?) which just about made me spit out my coffee the first time I read that...The internal bluetooth BMS screen gives better information than the shunt does - plus - its range is a lot better. I can use it in the camper. The Victron Shunt is a little weak.
I"m not a guru either but I have a feeling this will take me down the rabbit hole eventually :D I'm still concerned about some things which would be much more of an issue if I were full-time living on one - but, as a recreational weekend warrior I'll be fine - and I can see already the HUGE amount of power in the batter over lead acid. Pretty impressive actually.
Yup - I may have to break the rules and put a power switch on the brakeing system - the phantom draw on the the Autow brake is small, but still there. I'd like to just flip the master switch and not worry about it. Though the BMS will shut down the battey to keep me from being a total idiot again :\
SettingRecommended
Tail Current4%
The charger we use does have a lithium mode. As well as AGM and Lead Acid, and thats what I have it in -- Honestly, if it foats between 20 and 80% SOC - that actaully fine with me! its keeps the battery it its happy place. I just want to make sure I'm not having a problem that is an outlier. Where did you find the Peukert Exponent? That name still makes my inner 12 year old giggle.
I just remove the fuse on the bottom of the Autobrake in the galley to de-power it and limit my power loss when not towing.
It's mentioned in the documentation online. I just did a search for the term in the PDF, which I'm sure you already have. I completely nerd out on stuff like this, but had to use AI to understand what it means/what it's for.
Me too :) -- actualy right now I'm geeking out on an AI project as i write this. Openclaw is the greatest tool ever....
I’d be happy to, the next time my phone, battery and charger are in the same place I’ll fire it up and check. We had a short power outage a few days ago, and I pulled the battery into the house, but not the charger.
However, my battery is probably two generations back and half the size of a group 24, with no BMS. I think you’d do better to look into what your specific batt wants to see from the charger.
@Henry one tip to share if you haven't already: contact Victron tech support on the item you bought which will find you someone in the channel purchased- for example I got a Victron shunt and Victron shore charger separately; so I have to talk to different people who support the sales channel assigned by victron tech support, but once you get to the victron person they are pretty knowledgeable, and can give basic understanding of how it works with a none victron supplied lion battery, one level deeper than the manual.
@Sweeney Sooo…. What’s the status on the lithium apparatus, Gladys?
Honstly, I got busy then was laid up with the back -- I havn't gotten much further.
I have noticed that the battery is now charging to 100% - perhaps the onboard charger needed to 'learn' the battery or the battery 'learn' the charger. I'm also seeing 10 amp charges...was only getting 4-6 before...so something has gotten inself straightened out.
Honestly, I may pull the victron smart shunt out -- the battery BMS is probably far more accurate anyway, though I wouldn't have the historical tracking. I honestly don't need that anyway. The monitors were/are far more necessary on earlier batteries that lacked the sophisticated batteres made today.
Hmmm. So the Battery Management System provides information on charging and current/volatage in out? By bluetooth?
That eliminates the need for an app and capability from onboard AC charger, like victrons IP12/7 or 17.
And negate the need for the use of a powered shunt like Victrons.
Does the battery also pre-heat itself?
Yup sure does. Its got a warning that loads below 1 amp may not be accurate. It gives current voltage, current, power (wats)and capacity in amp hours remaining. It also tells battery temperature, cycle count. It also estimate battery life, and charge time remaining based on current load .
It also is self-heating. It can self-heat in two ways, steals 10 amps from the charge source (that is the required amperage to warm it) or, it can use the voltage from the battery itself to heat itself. I have not seen this yet, though I have considered popping it in a refrigerator for a few hours :)
Overall this seems like a great battery - I'll be using it the first time this weekend. I'll be abusing the battery this weekend -- leaving lights on etc. I want to 'abuse' this thing to see how it handles hard use cases. I'll turn off the charger and just see what it looks like when I get home. WIth 2 lights, on full, the stereo playing, fan running, and refrigerator plugged in -- at 79% it says I have 12 hours left.
I'm STILL not 100% on lithium, it really depends on your use case. If you boondock frequently, these definatley make sense -- but considering 9 times out of 10 I'm staying with electricity hookups, where the battery gets used is where I am charging my phone, computer, running my media center, and ceiling fan --- my 'charger' does not put out power to do all that. I"m using more power than the charger can put out -- this allows teh battery to pick up the slack. Then, when I turn things off the battery is brought up to 100%. Lead acid are really ideal for that situation. Ideally, a deep discharge.
I'm havn't decided if I'm going to put the solar panel up -- this is just about peak solar time with the sun nearing its highest, and longest, and I'm still not using the big-bertha of power users...the furnace. This is going to be interesting.
I don't think I would have bought this for my use case....except, now, lithium batteries, are at the same price as a good deep cycle battery, and, theoretically they have more cycle capacity as well. I honeslty killed the last 2 deep cycels by my own fault. Again something theoretrcially that BMS will prevent. I'm still on the fence.
I'm very interested in your 'boondocking' test results, especially if you decide to use solar at all. Interesting about the furnace being a power hog - how many watts does that draw? I figured, it being on propane, the only power needs would be the blower/fan.
I shall be living vicariously through you this weekend!
Well, @Sweeney you can write it off as business expense, right? Training and evaualtion? ;)
One thing I have noticed is its not easy to find auto shops, stereo installers or even RV repair places that can trouble shoot trailer-hookup, ctek, lithium and solar issues, from the TV start battery to the RV house battery.
Some just say "our insurance wont let us do anything solar" etc.
What it really comes down to is the ability to troubleshoot at the basic wiring level but understanding how new things added in the system, interface.
So you have that going for you at a high level.
I think there are far fewer auto electric shops than we once had. I feel lucky that the major u-haul is not so far from my house, and their trailer/hitch/electrics shop is not bad, because our local auto electric shop went out of business maybe 10 years ago.
If you are anywhere near fishing or recreational boat fleets, there is still a lot of custom marine electric/electronics work being done, including cool parts and accessories, solar, lithium batts, etc…
I have a lot of experience with the LiPo battery, victron charger (IP65 15A), victron smart shunt. It’s a long story, but i’ve had the setup for few years now. I currently have the CI recommended LiPo battery. It has a basic BMS in it. Here is what i know. First and foremost- configuring the smart shunt properly is a major PIA. If not impossible. If you dive into how it works, the parameters, etc you’ll quickly realize that its an estimate of battery SOC. AGM SOC measurement is based on voltage. Voltage decreases as SOC declines. So you can get a reasonable approximation of SOC. Since it kills the AGM battery if you go below 50%, precision doesnt matter so much. You gotta keep it charged up. Since LiPo voltage is constant until it is almost fully discharged, you cannot rely on voltage. Hence the complicated smart shunt parameters. BTW, as noted sbove, store your LiPo at 40-60%. They don’t like to sit fully charged. Also don’t go below 20%. Many BMS will shut down at 20% to prevent damage.
But on the smart shunt and SOC- if any one of your parameters you configure are even slightly off, you won’t get accurate SOC readings. I’ve been fiddling with the parameters for a few years now, done more research than a Nobel prize winner. I’ve only been able to get it sorta sometimes maybe accurate. It’s all a bit of a mystery. Here is what I’ve found. I use the Victron app for both the ip65 charger and the smart shunt. You can through a combination or these devices figure pretty closely if you’re 100% charged. Study the charging LiPo charging profile for the victron charger. Both devices will give you the total amps during a charging session. The charger data is better for this, it will show you total amps, bulk, maintenance etc. by knowing how many amps the battery took during the charge and comparing it to what your smart shunt said your SOC was before charging, you can get a sense of whether your parameters the smart shunt are good. Note that in my experience the smart shunt will often show 100% SOC before you actually get there. I know this because of the total amps charged per the charger report, when the smart shunt shows 100% before charging. It can be wildly off. You can force reset the SOC to 100% after fully charging. But that doesn’t do you much good if your shunt parameters are off. Your SOc reading will be off as you discharge. I’ve found that with 110Ah (?) battery, it doesn’t matter so much what my SOC is. I have more than enough capacity to run everything I have for days (5-6 days)
Also I have seen from research that some LiPo batteries with extra smart BMSs will end up fighting with your charger. That sounds like that maybe your problem. Both systems (the charger and the BMS) are trying to do similar or conflicting tasks. Since it’s harder to get a dumber LiPo charger, you really need a more basic BMS (which means battery).
