Heat is another advantage to LED...well, lack of heat.  Our galley light was left on, and the heat from the bulb scorched the plastic liner....burned through actually.   So I replaced it with an LED....no real damage, just  melted plastic.
The led is not as warm color wise, it's more blue than yellow, I find that really annoying.  It also seems to flicker, but that's not possible because they are powered.   I'm not a fan of LED at this point....even though they are cooler and much more energy efficient.   Yes, I did buy a "reputable" and quite expensive bulb....I can't recall the brand....regardless, it's probably made by the same sweatshop laborer as the cheap ones.
-G
