• ✅ Good news about our SSL certificate
    The previous technical issue that was preventing automatic renewal of the SSL certificate has now been resolved.
    The certificate renewed automatically, and should continue without any interruption or need for action on your part.
    Thank you for your patience! Now back to your regularly scheduled forum activity
Fire Rings
Jay & Valerie
I left my smudgepot back at my house in Texas and needed a fire pit for camping while we are up here. I had originally picked up the Outland Firebowl Mega from Costco but I must have received a bad unit as I could not get it to stay lit. So I returned it and picked up the Little Red Campfire. This is pretty slick, compact and very portable.
Here is a quick video review.
A couple of years ago, we had a wet and wild May gathering and one of the campers set up his LRC - it was great! I ended up with some extra REI dividend dollars so I got a Camp Chef Sequoia (not quite as compact, but it does come with a storage bag). It sat out in the garage for a while but then we finally brought it along on our October gathering - there was a pavillion in the campground but it was supposed to be cold and wet and not a lot going on in the area.
The fire pit really saved the gathering - the weather was so crummy on Saturday, most of us probably would have ended up hanging out in our trailers otherwise. Gave off a decent amount of heat for a fairly large group - we went through maybe a full 20-lb propane tank in a long day of use at a moderately high setting. I would guess that individual/couple use would require fewer BTUs and a lot less fuel.
When we're camping by ourselves, we'll usually just set up what the backpackers at REI used to call the "Washington campfire" - our UCO candle lantern. Negligible heat, but if you like sitting around a fire, it's better than nothing.
Another trick we discovered at a sweltering Midwest gathering - if anyone has a long string of red flashing LED lights (and some kind of power source), curled up in a circle, it makes a reasonable campfire facsimile - without the heat.
