We have a 2017 550, with the original Marinco charger built in. Put in a new Enersys
DataSafe 70ah AGM battery in it two years ago. Always plugged in while not in use.
Now, this year, if I unplug the charger, voltage is at 13 v, but if it sits for 12 hours, voltage drops to 12.4 (80%).
It does this whether the main disconnect is on or off. I checked parasitic draw, and it is 4 milliamps or .004 amp, that is not the issue.
AGM batteries are running over $200 now, so I don't want to replace unless I know it is the problem.
However, if it needs to be changed out, I'd rather do it at home than try to find one on the road.
Does this sound like a normal battery function?
