Dometic 12 Volt power cord
hiadventurer
The male end of my Dometic 12 volt Power Cord fell apart the other day. I just need to replace the male end in which the cord ends are screwed to the plug, ( two small screws), (not soldered). I can replace the tire cord for $35 but thought if someone out there knew of source for the male end only it would be cheaper...Thanks R
I have used these, it includes a 10A fuse, probably the 8 amp fuse from the original can be put in, though 10A is almost certainly safe enough. The company makes very high quality stuff, mostly for marine applications.
https://www.bluesea.com/
(I have no connection with the company, just a satisfied customer)
