Les Izmore
My apologies if anyone has already posted about this. I didn't see anything in several pages of search results, so here goes.
We are full timing and that means our Dometic goes in and out of the galley a LOT. It has always been a little tenuous lifting it out by the small lips below where the factory handle is installed. Add Florida heat and humidity causing more condensation to form on the outside of the cooler and the problem is amplified. It looked to us like a disaster waiting to happen.
So we visited REI yesterday and bought 2 feet of nylon web strapping, then we stopped at Lowes to get four 6MM Phillips-head bolts and four wide fender washers.
I folded about 1" at each end of the strapping and sewed that in place. Then I used the awl on my Swiss Army knife to puncture a hole through both layers of the webbing. Next I used some needle nose scissors to enlarge the hole enough for the bolt to pass thru. I then install the completed assembly as shown in the picture above.
After the first use it was clear that this was something I should have done a LONG time ago. It works great, saves my back and makes life just a bit simpler...
