TheSongDogHouse
Nice upgrade and writeup Sweeney.
Purty high tech with the 3d printer and all but fitting with the Maker culture of old and new embodied in the CampInn manufacture.
I think AGM makes a lot of sense, and many thanks to Seth, Randy and others on the SuperVictron and you and Steve on the FullRiver. Nice to know we have two proven options available online/in stores, with a bit of a drive.
You referenced mine so heres my story:
When my old shore charger failed it cooked the 2.0 year old lead acid (Everstart?), gradually - a known failure mode of the first model Marinco in my 2010.
I of course had no clue as I'd never checked it, and in a beery haze once parked in the high desert wondered "what the heck is that blinky light under there...fire flies in the Coconino's? Thats a new one...? Sure it was covered in the owners brief which was 8 hours of cracking up with Craig, amidst about a hunnert things with no notes. Plus RTFM as they say on car forums...Derp! Naw!
Plus No way I'm crawling under there with the rattlesnakes, scorpions and jumping cholla..."
My first tell was the flickering lights as shote cahreger was parked in garage full time plugged into the wall, when interior lights turned on, gradually flickering then holding steady...but in a few weeks, flickering in a cycle (60hz?) from the AC leaking past the battery buffer thru Marinco into DC?
This was gradual at first as the bat-tree slowly cooked. See, I mistakenly thought it was an AGM, so I-never-checked-the-water-levels...derp!
When I did take it out, and took to my friendly local Batteries Plus they said "we've never seen one that dry" and "sorry no way to bring that back to life"
So with substantial dithering, mental anguish, and failed attempts dropping the water tank, digging underneath to find wires, and finally patient coaching by Cary and Craig on how to tie in instead by the battery bay,
I replaced the Marinco that was underneath between tanks, with a Noco5, mounted inside the right hand galley bin, rewired and left the Marinco where it was, wires cut and sealed, no power dayed, pinioned under the CampInn rear hitch option and bumper mount..."let the scorpions feed upon the accursed thing..."
I'd read about Seths experience "having to ship back a Victron with a broken corner the Fedex guys dropped on the loading dock"
And said to myself, Self, I need to find something I could get on the road just about anywhere between Left Armpit, East TX and Ekalaka, MT
"off the shelf" at Wally World, Auto Zone, OReillys, Batteries Plus etc and install with my primitive DIY skilz...
as its Murphys Law # (something in low digits) that yer essential technology WILL fail when you most need it and
I dont want to be parked on the playa at Quartzite, for example waiting for it to ship in two weeks...or more.
So, since Bat-tree Plus has the widest numbers of stores on the nationwide map, I went back to my local Batteries Plus - really nice guys- in past I'd used them to recondition a pair of Sears Die Hard AGMs in my tent trailer- 50 and 80% after 8 years of use, recharging with a desulfidator on solar panel in between trips...those Diehards were made by Oddysea when they were good back in the day...
I had earlier sourced a plus sized option for my Alltrack tow vehicle at AutoZone in Moorhead MN
-an Odyseas Yellow Top AGM when the OEM battree died in Fargo as I wanted the durability of AGM on bumpy roads, like in my truck back in my wasted youth in baja camping days...
and coded my BMS in the VW ECU with the VCDS to charge that new batt on AGM cycle.
So my car battree had been charging the lead acid in CI at the higher AGM charge via CTEK while driving down the road...derp again.
Back to the CI:
Battree Plus sold me on their super duper version of a super AGM, (kinda like but not as good as the SuperVictron) and "lucky me: the last on shelf" but it wuz unfortunately, dayed...too long on the shelf I guess...turns out the service tech at store needed training. It wasnt dayed just seemed like it but too late...i'd returned it for refund.
Cuz after three weeks of promising "on the next truck", for another super duper agm I went over across the street to O'Reilys and got a Duracell auto AGM and bot some bolt on marine terminals to adapt the car battery to my CI. See, now I have a plus sized AGM in TV and an OTS get it anywhere AGM in the CI...pretty cool, hey?
Well, of course I didnt realize the battery terminals are on the back side of the auto batteries compared to marine trolling motor lead acids...
And thus too tight to fit the bay, (my 2010 came without the DC fuse installed after 2012, but had extra wiring from the added solar panel and CTEK plus AutoW added, in the galley bin.
So I have less room to work with and zero chance of understanding what wires go where...)
(Yes I have a voltmeter-ammeter and two semesters of college EE at the Boat School, lost in the mist of time...who do you think I am- Sweeney? steve, Seth? I get brain damage just remebering all this...)
But with some caveman chiseling on the wooden battery brace bar I made do...and it all fit nice and snug! That sucka aint going no-where, I chortled remembering bouncing the CI thru 90 degrees of tilt side to side in and out of ruts bounding two feet in the air on the ungraded since last winters USFS roads...
It held up good for one more trip but
Dammit I killed that bat-tree dayed leaving in outside storage three months with an overhead light on low...derp! 7.0 on the meter...the rooftop solar has brought it back to 11.5, but thats still dayed.
So, back to being dependent on far away wholesalers like Continental for the Precision battery...but
Thanks to Sweeney and Steve now I know I can go get an AGM super duper Victron or Sweeneys whatzit? in Group 24, off the shelf...ordered somewhere.
Or another off the shelf lead acid marine trolling battree, or just a car auto AGM with marine terminal add ons bolted in...
Just go to Advance Auto, Autozone, Walmart in the South, just avoid Bat-tree Plus...
Back to the CI:
