Screw a big eye bolt in the back of the garage, then use the item below to pull the trailer in slowly, while a helper steers the tongue end. I have one of these and it is amazing.
https://www.amazon.com/XSTRAP-Heavy-Duty-Breaking-Strength-Hoist/dp/B07VFF9Z5B/ref=sr_1_3?crid=1XY25SP4J2972&keywords=rope+hoist&qid=1701084158&sprefix=rope+hois,aps,165&sr=8-3&th=1
^^^this, +1<snip>
I've had similar (and worse than 5% grade) campsites that require steep grade backing up. Or having to reverse course on a bad road and do a 3-point turn up a hill. Best to learn the skill with the trailer attached to the tow vehicle; you never know when you'll need it.
I do the same even in campgrounds- put a couple chocks where I want wheels to end up and back towards them...I have two driveway markers that I place at the entrance to the garage. They are wide enough so I can see them with the side mirrors. They provide an aiming point.
LOL! Me too! I have been burned bad by Goolag Maps- tryna get to our farmers house from a different direction than usual, and the dang thing routed me down a "road" that became a tractor track for last half mile...fortunately a tdiwagon (with a 96hp diesel tractor like engine)I didn't even thnk of the roads....We were in South Dakota and the GPS sent me down a logging road. I am still not sure how I made it out of there in one piece...That one was embarrassing enough at the time, I didn't make it to the camper confessional, though it probably should have!
how about a trailer valet? New Home
There are models of Trailer Valet that will work with our campers. The base model bolts to the frame and won't work with ours. But, the other models do because they use a ball and you just lock that into your coupler.Nope. Trailer Valet does not work with our frames. The mount requires two fully boxed edges. While the outward facing portion of the frame is a 2" box ... the inside facing portion of the frame is an "L" shape.
Returned my TV yesterday and quickly got good at backing trailer in single garage, as Ken & Peggy suggested above.
Trailer Valet XL
Will definitely keep working on backing. Looking for an alternative until I am confident in my backing.My suggestion is to practice your backing skills so you can get your camper garaged unassisted. I'm not aware of a motorized product that will let you move it separate from your vehicle, although that would be great . Maybe someone else on the forum has a similar situation and will have an answer for you Best of luck.
I love this video.Before I learned how to back up the trailer, I considered one of these eyebolt solutions, but when it comes time to get it out...you've got to move a heavy trailer down an incline without the brakes of the tow vehicle to stop it. Potentially setting yourself up for a roll-way camper.
But, the best thing to do is learn how to back up, its not that hard. Besides that, eventually, you'll find a campsite you want but need to back up into it....Knowledge is power.
I like "loloho"'s take on it.
BTW, never let people watching you intimidate you. If someone his being you, before you start, let them pass you. Ita easier if you don't feel like you're holding someone up. Getting a set of FRS radios can make communication easier between you and your safety spotter. Eventaully you'll back up without one, just go slow slow slow and always GOAL. Get Out And Look....there's no shame on it.
Every one of us have gone through this. Ignore the spectators --- especially the ones with score cards
I love this video.
 BTW --- see this is your first thread.   Welcome to the community.    Do you own a CI?   What model?   How long have you had it?
   BTW --- see this is your first thread.   Welcome to the community.    Do you own a CI?   What model?   How long have you had it?If the tongue weight for Travel Valet XL says minimum of 500 lb. Tongue weight in the specifications. Does that matter? I am guessing our 560 is much lighter than that. I would love to get one of these for tight spaces.There are models of Trailer Valet that will work with our campers. The base model bolts to the frame and won't work with ours. But, the other models do because they use a ball and you just lock that into your coupler.
Trailer Valet XL
Yep ... I should have been more clear. The XL is a true beast and would work. The TV 5X was the one that I just could not mount.
Good question.If the tongue weight for Travel Valet XL says minimum of 500 lb. Tongue weight in the specifications. Does that matter? I am guessing our 560 is much lighter than that. I would love to get one of these for tight spaces.
