hiadventurer
Anyone else experience this. If so any solution to eliminate it? I have checked the pads and adjusted brakes and they are sound..R
How long have you had the trailer?
Randy
We received our trailer April of 2016. So, it doesn't have a ton of use on the brakes. Even if not tuned perfectly, they have been nice to have.
From page 40 of the Owner's Manual, rev 8/21/2012, Using Trailer Brakes:
To properly set the brakes:
1. Find a straight section of road, clear of other traffic.To check the brake function:
2. Slow down to a safe speed, (less than 20 mph. Slower on ice)
3. Adjust the brakes to a low setting (2-3).
4. Apply the brakes hard.
5. If the brakes do not lock-up or skid, turn up the brakes.
6. When the brakes DO lock-up or skid, turn the brakes down.
7. The best brake setting is just below where they start to skid.
8. You will have to readjust the brakes as road conditions change.
1. Turn the brake strength up to the highest setting.My take-aways:
2. Drive about 20 mph. Put the car in neutral and coast.
3. Apply the trailer brakes using the manual override on the brake controller. You should feel the brakes slow you down.
4. If you don't feel the brakes pull, they may need cleaning. To clean the brakes, drive at 20 mph and pulse the trailer brakes ON for 20 seconds, OFF for 5 seconds until you start to feel them pull. (usually less than 1/4 mile)
5. Repeat steps 2&3. If they still aren't pulling, inspect the brakes.
1. I haven't been applying the brakes hard enough in step 4. I've had my controller maxed and still not locked the tires.
2. One does want to feel some pull when the brakes engage. Otherwise, what is the point of having brakes?
3. I may need to pop of the hub caps and inspect/clean the brakes. After two years the bearings are due for packing anyway. Perhaps eliminating any contamination/dust in the drums will reduce squeaking.
Cheers,
--Ken
The brake size on your camper is not large enough to normally lock up a wheel. Being able to lock up the brakes is not something you would shoot for with your Camp-Inn.
When you have your brakes set to an ideal position you should not feel the camper braking behind you. You should also not feel the camper pushing you either. The brake pedal pressure and feel in the tow vehicle should be exactly the same when the camper is connected as it is when it is not connected if you have the brake controller set right. This is how you set your brake controller with your Camp-Inn trailer.
It is a common mistake I see people doing trailering, to set the brake controller so they always feel the trailer braking behind them as an assurance it is working (I am as guilty of it as anyone). That is too high a setting. This will wear out the brakes and most notably the tires on the braked axle prematurely. When an owner reports that they had an unusually short life span on the tires of the camper a quick look at the build sheet for it will always show it is a brake equipped camper. That means the owner was wearing out the tires with trailer braking, either by having the brake controller set to high all the time or by doing serious mountain driving and using the camper's brakes as a "drag chute" coming down the mountains.
If you don't have the brake controller set high enough you will know, the camper will push you at stop signs and you will have to push harder on the "whoa" pedal to stop.
Short Short Tr, your take-away #1 doesn’t sound right. Have you ever adjusted the brakes - I mean the distance from the shoes to the drum?
AFAIK all the other adjustments at the controller come after hitting the adjusters. Unlike modern cars with drum brakes, the trailer brakes are not self-adjusting.
Hi Carey, If I want to opt for electric brakes, would I have to purchase a complete axle and hubs/brakes? or can it be retrofitted with just the hubs/brakes? if so what is the brand name or part number or better yet what is needed that you would recommend converting a non-electric brake 2012 560 model? But I'm sure they would be different for SUV vs non SUV height? I'm sure I could get it done locally at a trailer and frame shop but Roughly what would be the cost to be done at your factory (roughly), Thank youThe brake size on your camper is not large enough to normally lock up a wheel. Being able to lock up the brakes is not something you would shoot for with your Camp-Inn.
