The Short Short Trailer
PART 1
Hello All,
This post pertains to securing my solar panel from idle hands. The solutions I suggest will not stop a determined thief but will be annoying enough that things will probably stay put against the casual opportunist without tools. I bought my materials through McMaster-Carr. It is, by far, my favorite website because the search mechanisms are so helpful. Supply is great and delivery is fast, but it does come at a premium. If you have time and like the hunt, I am sure you can find all of these materials more cheaply at other suppliers.
Basic Theory:
Goal: lock my panel to my trailer via a steel cable.
Problem: I don't want to see (or trip over) additional cables and clutter in my camp site.
Initial Solution: heat shrink my 15' power cable and the steel cable together into one bundle. Loop and lock ends of the steel cable to my bumper and to a drilled hole in the solar panel's frame. Much cleaner (visually and physically). I considered just cable-tieing them together but campsites are often dusty/sandy and I didn't want to stow a bunch of extra dirt between the cables.
Here are the materials I bought:
__steel cable
__combination locks
__crush sleeves (for making loops in the cable ends)
__roll of heat shrink tubing
Here are most of the tools I used:
__heat gun (or a candle might work if you're VERY patient)
__tape measure
__electrical tape
__drill driver
__#2 phillips screw driver
__pick
__scissors
__vise
__two small drill bits, roughly equal size, at least one larger than the loop on your lock.
__(I wished I had a fish tape for threading the cables)
Up next... Fabrication Process.
Hello All,
Basic Theory:
__steel cable
__combination locks
__tape measure
__electrical tape
__drill driver
__pick
__scissors
__vise
