The Battery Tender failed on my 2012 560 so I ordered a new replacement from CampInn and recorded the process in case others need to do it on their trailer. Here is the step by step video.
It was a mighty max AGM battery. However, it was slightly too tall. Watch your measurements because I thought I had everything worked out. Have to return it and find a better fit. Tolerances are tight in that compartment...but that also shows just how precision these CampInn trailers are...everything fits like a glove.Thanks also for that look into the battery compartment!
What battery did you end up using as a replacement?
Thanks. Good point, hadn't even thought about that since I didn't have the receiver hitch.Great job Jay. I would add if your trailer has a hitch it will have to be dropped to get to the battery tender. Not difficult just a few large nuts to loosen. It is heavy so be careful...
No problem. It was a pretty easy job and can be done pretty quickly.Thanks for the video Jay. Very insightful in case we have to replace the charger. We don’t have a water system on our 550. So, I think the accessibility should be slightly better.
Hi Bob, Sorry, did not see this until now. Are you still having issues? If it is popping the breaker then you have a short elsewhere in the system. Cary provides a pretty detailed troubleshooting guidelines in the manual. You might want to look through that first. I would start at the battery and work back from there. There are a lot of wires in that battery box. There are also a lot of wires underneath the trailer as you saw in the video. Short can be difficult to track down.Jay
I am Bob, I liked your video . I just got a Raindrop 560 ultra 2005. The Battery was bad and shorted the charger,
so I changed it with a Battery Tender 12v 5 amp model. I put it in the same way the old one came out. For some reason
it is poping the circut braker on the GFI plug. can you help?
Bob153
