Table Extension How Do You Store The Table Extender For Travel?
Discussion in 'Camp-Inn Options & Accessories' started by sarmay, Oct 4, 2018.
  1. Cary Winch
    The front storage is about the same size on a 560 as a 550. It is narrower but deeper, the total volume comes out about the same. The furnace option affects the lower 560 storage space much more than on a 550 because it is a totally different layout. But, the furnace does does not affect the upper 560 storage nearly as much as it does on the 550.
    Van_and_Terri and M&L like this.
  2. Jim & Selma
    Jim & Selma Novice
    We threw in the towel too. I made a sleeve for the table extension which sits on the table on the counter just fine. I made another one for the side table too, since that and cooler both get rub marks.
    Keeps everything from getting scratched as we travel those wonderful back roads.
    David & Diane and Van_and_Terri like this.
  3. campdude
    campdude Ranger
    Great way to cushion and protect it.
    Kevin likes this.
  4. Larry Running
    Larry Running Junior Ranger Donating Member
    I put small velcro strips 1 1/2" x 1/2" (I used clear velcro) to the galley wall above the cooler and corresponding strips on the extension. I sits across the cooler walls. Simple and does not affect anything else. It's always handy if I want to use it and never in the way.
  5. Lipster
    Lipster Junior Ranger
    I screwed a 1x2 to the bottom of the big table. It faces you when it is folded and stored (use screws that are not too long!).
    I drilled 4 quarter inch shallow holes in that wood piece, and glued in some 1/4" rare earth earth magnets, flush with the wood's surface. The extension is then placed on the wood and it holds just fine.
