I bought a set of these to help keep my "fits mattresses up to 20 deep!" mattress pad from bunching up on my 4" deep Camp-Inn mattress:
http://www.holdup-suspenders.com/stay-downs.htm
http://www.amazon.com/Crisscross-F...1_14?s=bedbath&ie=UTF8&qid=1445010645&sr=1-14
So far, they work great although it was "fun" putting them on. I shortened the elastic straps as short as they will go (see 20" vs. 4" comment above) - basically until the two velcro tabs met in the center. Then I put the mattress pad on the bed, crawled under the mattress, attached the clips to what I guessed were the corners of the mattress pad "skirt," made sure the straps weren't twisted and everything was OK. Then I crawled out from under the mattress, sweaty and disheveled, but with a nice, taut mattress pad.
I will never claim to be the smartest person in the room....
After a season in the camper, everything is still holding up well - the clips seem to be holding the mattress pad hem nice and secure, the clips are plastic so they don't tear/abrade whatever crappy material they use to make mattress pad skirts, the elastic straps haven't lost their stretch, and if you're lucky, you can also stretch the corners of your fitted sheet and hold both the mattress pad and fitted sheet taut at the same time!
p.s. I haven't felt the clips through the mattress although that might be a concern.
