Fall Colors Tour
JohnC
I picked up my new 560 this summer and spent 3 weeks bringing it home. Since then I have been waiting for smaller crowds and cooler weather. The time had arrived.
I planned a journey to photograph some fall colors. I’ve been doing this every year for about 8 years now. I started in the Eastern Sierra which is where I always go. There were some beautiful colors, but also some very smoky skies from the not too far off, fires of the time. I stayed at the fairgrounds in Bishop. Definitely some pros and cons to that stay.
Although I technically had hookups, I chose not to use them as I wanted to see how my rooftop solar would do while having a fridge running DC from the house battery the whole time. Even with cloudy and smoky skies (every day had a red/orange sun and plenty of smoke and clouds) the battery always topped off each day, usually by mid day. The beauty of it was that the solar was always pulling some amount of power as the sky varied between better/worse conditions. Over the course of the day, it was always enough.
I left there and journeyed up to the Sun Valley area of Idaho where there were more amazing colors. I stayed with some friends so the 560 stayed outside while I and the Dometic fridge came inside. It’s an absolutely beautiful area, especially when the colors are popping. But after a few days, snow came early and it was time to leave.
Leaving there, I spent the night in Idaho Falls where temps reached just under freezing. I stayed in the local KOA where I had a chance to try my $29 Vornado ceramic heater. Although it has a 375 watt and 750 watt setting, the 375 was plenty. The 750 was way too hot.
The next night was spent in Battle Mountain, NV where overnight temps were, again, just below freezing and the Vornado performed perfectly with shore power.
Leaving Battle Mtn, I headed to Death Valley for a couple of days on my way home. I had not actually planned the return trip when I started the journey, but decided Death Valley would be a great way to try a new route home and see an amazing place. You can do things like that when you are retired. ;) Needless to say, dry camping in Death Valley, there was no shortage of solar power available.
I have to say, I was really pleased with how well the solar worked on this trip. And I love having a fridge instead of a cooler of ice and water. It was also another chance for me to get more familiar with everything associated with having a trailer. The first trip home from the factory was definitely a learning experience. This one was more comfortable, even though I’m still far from an expert.
It was an awesome trip. Can’t wait for the next one!
This was the morning leaving Bishop. Usually the red sun and smoke took until later in the day to show up.
Just above North Lake on Bishop Creek Road.
This one is on the south fork of Bishop Creek Road.
En route from Bishop, CA to Sun Valley, ID.
The Bow Bridge in Hailey, ID.
A farm near Gannett, ID.
I think there were more colors on the ground in the Twin Falls KOA, than on the trees.
Have you tried the Vornado on the CI house battery for a quick warmup, and how much juice did it suck?
Most others I've seen are in 900a range and too much for my old tent trailer dual AGMs, to run long in their elderly state...MrBuddy heater is a bit much in the CI...
and a CO death hazard...;)
So, kinda curious if you can in a pinch weather a really really cold nite if you watch closely...on and off a couple three times.
LovelyWife is a cooler but imma heater, so theres that,
but helps to be prepared...
In my short period of ownership I do believe the trailers are very well insulated. Yes, they will get cold inside depending upon the outside temps, but with two people and/or heavier covers I think they are fine to use in colder temps, certainly at least down to the neighborhood of freezing.
The Vornado runs on 110 so you really cannot plug it into the house battery at all. I have one solar generator currently with another on the way. Those will run a 110 appliance but depending upon the draw and size of the sogen, not for very long. My current one is 720Wh so it wouldn't last 2 hours on the lower setting. I guess if your intent was to run it for a few minutes you could do that, but again, not directly from the house battery.
The ceramic heaters are great if you have shore power but you better be prepared to bundle up or not go depending upon temps and availability of shore power where you go. I could have done without it on this trip but I wanted to try it, and it proved nice to have. Well worth the cost.
Thanks, John!
I look forward to using the CI down to and below freezing- got some experience snow camping in a USArmy bivvy bag/sleep system and cold weather tent camping...this is a glampinn luxury upgrade!
Guess I'll just have to winterize her and remember not to use the kitchen tap...;)
I did take the sprayer attachment off one night in Idaho when it was supposed to hit the low 20s. I think the plumbing is the main risk of freezing temps. I wouldn’t be too worried about the water tanks themselves freezing.
Hi.
Thank you for your post. We are scheduling a retrofit to our #787 to add the rooftop solar. Your post is the second report we have seen of the solar working well in less-than-sunny conditions which is helpful to know.
Beautiful photos!
Hi.
Beautiful photos!
Thank you. You'll like the built in solar. Convenience at it's finest. As long as you have sun, you pretty much don't have to think about it at all. Of course heavy shade and bad weather can always be an issue.
