Van_and_Terri
We just purchased a Clam Screen Room and cannot believe how fast and easy it is to setup. We went for the 72 x 72 inch. Just perfect for 2 people. They make much larger ones too. www.clamoutdoors.com
My testing... The door isn't wide enough. My sister has one, and we tried to see if it work last year. I really wanted it to work, but with one door and the shape, you just can't fit it around the teardrop. It you wanted it only over the hatch, do not use the table extension nor the cooler side table, maybe. You can't get it past the fenders. Trying that, just the hatch only and no tables, it was still awkward.
For me, that limited usage, and for one person to set up it actually was a bit tricky. I can set up the Northern Breeze by myself by using the teardrop itself to drape the tent over and then attach the poles. (Thanks Jean for the lessons on how to do that.)
If I want only a standalone screen tent, I might consider the smaller 4 sided Clam to set up away from the TD, but the 6 sided wasn't for me.
As with anything, that's just my opinion. I could be wrong and likely am.
