Wanted to give a little solar panel data for folks after a week of boondocking in northern Minnesota.
We recently bought the 55 watt panel from UL Solar, and this was our first chance to try it out. We spend a week every year camping at
Campers' Paradise, an island accessible by causeway in northern Minnesota. Our campsite was well shaded, so we only were getting about 4-6 hours of direct sunlight per day (when it was clear - our tear is the RainMaker after all) which required periodically moving the panel to take full advantage of, and indirect light the rest of the day.
After fully charging (but unplugged), our battery usually reads 12.6. We used the fantastic fan most of each night and used the interior lights for 2-3 hours. Other than that, only minimal battery use. Here is the voltage pattern for the week:
Day / Morning / Evening / Weather
Sun / N/A / 12.6
Mon / 12.2 / 12.6 / Sunny
Tue / 12.1 / 12.3 / Rainy-Cloudy
Wed / 11.6 / 12.4 / Sunny
Thur/ 11.8 / 12.0 / Storms Cloudy
Fri / 11.2 / 11.6 / Cloudy
Sat / 11.0 / 11.4 / Sunny (Not Around to move panel)
Sun / 10.8
What we learned: Consistent with past experience, the battery alone is sufficient for a weekend (3-day, 2 night) trip at our level of usage. Using the 55-watt panel would recharge each day's usage if it was sunny and we were around to to move it around to follow the sun. Given sub-optimal weather and limited sunlight, the panel was still sufficient to maintain a usable charge for a week. The combination of bad weather and not being around on the sunny day left us marginal on Sunday morning - we would have needed to have good weather for a solid recharge, or would have needed to recharge using shore power or tow vehicle.
One conclusion for us is that rather than investing in a larger panel, having a longer cable available would have allowed better placement of the panel. Overall, we're pleased with the results. It was very nice to extend the battery life for the full week without needing to restrict battery usage.
