Old, but lightly used by three different astronomers over the years.  It’s still in good condition, and everything works.  Probably time again though for some routine maintenance. I’ve put only about 1200 miles on it since 2018, and the two previous owners probably didn’t use it that much either.
Not sure what came standard back then. This is the narrower version that’s not made anymore. It does have a heater that can be used when the trailer is plugged into an AC outlet. The battery is brand new. I replaced the tires and wheel bearings when I bought it in 2018, and had the trailer sealed. Added a spare tire. The galley and cabin lights can be switched to either white or red light (for night vision). The memory foam mattress is still comfy. The trailer has always been stored in a garage when not in use. It was transported in a moving van when I moved from Georgia to Wisconsin. It’s been a joy to use, as I’m sure you all know, but my travel days are over.
I’ve had a 50% scammer response rate on Craigs List so far, so hoping this place is a bit more civil. Asking $6400 cash, with buyer picking up in person. Located in Sun Prairie WI. If you’re coming a ways, Necedah is about an hour up the road, if you feel like having any servicing done there. If not sold/picked up by Oct 26, will relist next May.
Thanks for looking!
Alex
Text 770.827.3449
Thanks for looking!
Alex
Text 770.827.3449
