trip routing
Discussion in 'Trip Planning' started by AnnaSteve, Feb 26, 2011.
  1. AnnaSteve
    AnnaSteve Novice
    Who knows of a trip routing service the way KOA use to be where you put in point a to point b and the maps and written directions show camp grounds along the way and a long list of other things to pick from like gas stations,avoid tunnels etc.Thanks :)
  2. KathyBob
    KathyBob Junior Ranger
    We depend on AAA for this all the time.
  3. Mick'nSarah
    Mick'nSarah Junior Ranger
    AAA has a program called tripcheck. It is all online, and you have to be a member. My mom is and we used it for our trip out to pick up the trailer. It works ok. I think I mostly references large landmarks and hotels. That is what we used it for.
    Not sure about many campgrounds...I usually just did a search in the area or took advice from other folks. I would love to hear if anyone else has luck with finding something.
  4. AnnaSteve
    AnnaSteve Novice
    KathyBob & Mick'nSarah we found AAA tripcheck also and it looks ok but we were looking for something a little more like KOA or Good Sam trip router use to be why they changed it i dont know and neither do they. Thanks :)
  5. Ladymc
    Ladymc Novice
    Yeah I want that info too!
  6. AnnaSteve
    AnnaSteve Novice
    ladymc KOA & Good Sam were perfect but they both changed and i cant get to the true reason. :)
  7. pat walsh
    pat walsh Junior Ranger
    I use the AAA Trip Tik it isn't terribly user friendly but if you are a member of AAA you can save your trips. It will show campgrounds if you zoom in to about City level. The printouts are very detailed so I usually just print the overview and use my ipod or Garmin for directions as we drive. One thing that is confusing is if you save a trip and later retrieve it, make changes and save again - it saves as a new trip so you have to keep renameing and deleting old trips. It is easy to see miles and times between 2 points which I like.
