Tow vehicle fuse.
rrunneals
I’m wiring the seven pin connector on my tow vehicle and I don’t know what size fuse to use for the hot wire to charge the battery of the tear drop I was thinking that a 30 amp fuse should be enough.
Robert,
A 30amp would be correct on that.
Make sure the ground wire coming from the 7 pin is also at least 10ga.
