Wendell Ann Hanks
Our 560 model does not show on the battery meter it is charging when the truck's power cord is connected to the trailer. All seven of the connections at the truck's connector show power.
What is a best guess as to why there is no evidence of the battery charging once the electrical is hooked up. To test, I use the meter that connects to the outlet, right side, in the kitchen. I make sure the master switch is "on." When hooked to the truck the trailer's running lights and the stop and turn signals work fine.
No fuses are blown.
What is a procedure that I can use to determine why no charging of the battery.
Many thanks.
Wendell
No fuses are blown.
Many thanks.
Wendell
