Best way to empty the Grey Water Tank is...??
Since I'm going to start using the Water tanks, new faucet/pump upgraded, I was wondering what's the best way people use to maintain and drain the Grey water tank.
Initially when I was outfitting "Le Droppe". I got a black hose thinking I'd just hook it up and put other end in the Water Dump openings on the "Connected" sites.
Just seemed like a hassle and thought well, just drain into a plastic dish tub and then pour that into the site's drain. Then you had the problem of pouring into the drain and keeping the drain opened, some are curved. So I got the Big Boys connectors, the corner adapter and then a 3 gallon Water bottle, the blue ones, and cut the bottom off. That way I can just put on the "Bottle Funnel" neck going into the drain, hold the flap cap open and pour. Again, it works but enh??? not the best solution me thinks...
So before I try to "Reinvent the Wheel" thought I'd check to see how others work it. It helps eliminate the "Doh!!!" factor of "Yeah, Geeezzee that makes sense"...
Thoughts???
Thanks...
Thoughts???
Thanks...
