Furnace Not Lighting Initially
LisaNKevin
We're camping in N. Florida for New Year's (Happy 2017!) and it's cold, mid-20's. Tried the furnace, only cold air then shut self off. I turned it back on and it worked. A few hours later, same thing. Cold air, turned off, tried again, success. Any thoughts?
The tank was recently refilled for the first time.
That's not a blurry picture, it's frost!
full
This hasn't happened to me, but I'm pretty sure that there's a valve on the tank that can freeze shut.
Had a similar problem this year, Campinn fixed a loose wire in thermostat. Furnace works fine now.
When our propane tank was newly filled, our furnace did that (in TWO previous non-Camp-Inn trailers). It was explained in the owners manual (of one or the other) that when the propane tank has been newly installed, as it would be if you just had it filled, there can be a bit of a lag in getting propane through the line to the appliance. If that happens, the furnace's built-in protection for the electronic ignition will shut off when it doesn't sense propane. That might be the case with yours, as it worked the next time you turned it on.
That is a good idea Bear. My furnace only worked the first night. I've been emailing Cary and he had me doing some testing. It turned out to be a faulty altitude compensator which should arrive in the mail today. It is a bummer I had the furnace problems as it was getting down into the teens but Camp-Inn Customer Service is tops. I just chalk everything up as being part of the adventure of owning a teardrop. Besides my old Little Guy didn't even have a furnace.
Is the altitude compensator the same device as the propane regulator?
