Fixed blade or folder for a dedicated camp kitchen knife?
Fahimden
For those of you who actually cook a lot at camp, do you prefer a small fixed blade or a folder as the dedicated camp-kitchen knife?
A folder is easier to toss in a pocket, but cleaning food out of the pivot is the part that makes me question it. A small fixed blade seems simpler, but then you have the sheath and storage to deal with.
What blade length has actually been useful for you rather than just looking good on paper?
I use a cheap 3-piece fixed set. A chopping knife, an in-betweener, and a paring knife. No way would I use a folding knife for meal prep/cooking. Spot on about that crevice getting gunked up and spreading contamination.
Got to admit, the box knife has been used more than once in the galley -- a quick wrapper opening. But would I ever cut a meat or something like that - absolutely not. Keep a cheap walmart grade kitchen knife in its shealth for anything food prep.
…Keep a cheap walmart grade kitchen knife in its shealth for anything food prep.
This. I use the same style as I do in the kitchen at home; a chef’s knife, but an inexpensive version. Plus a small slicer that can go on a picnic in its plastic cover, and a paring knife, medium and small cutting boards…
A folder doesn’t work for me with food. Too hard to clean. If i’m away from camp or home a folder gets more use, but it may be a fixed if hiking or boating.
What do you use @Fahimden ?
A paring knife and a chefs knife is all i need. Something in the $10 farberware knife does the tric. If I'm frisky, I'll head down to the restaurants supply and picking one up there. At home, I have a nicer set -- but in the camper everything gets beat up as I'm rolling down the highway - its not really worth spending much. Frankly, the Farberware if kept in its shealth does just fine.
The biggest problem is not putting them in a dishwasher to get banged around...and once a year or so throwing them on a whetstone - I can shave with mine when I'm done (Hence the moniker)
@Fahimden - what do you use? No wrong answer - a Japanese chef knife is a perfectly good answer.
The “sheath” on my chef’s knife is cereal box cardboard and masking tape. It gets the job done, good enough!
The cheapo kithchen knifes come with a plastic sheath - and a built in duller, you know the 'v' channels that removes any residular sharp edge and replaces it with a jagged edge?
I keep a worksharp pocket in the camper -- its prodcues an 'ok' edge --- but not anything I'd write home about. Ever since I discovered the Ken Onion sharpening system (by worksharp) its my go-to, if not that then the tormek water stone system The trouble is one produces a stone 'flat' the other produces a convex edge. THe convex edge lasts longer, but makes it functionally incompatible with 'stone' unless you want to remove a fair amount of metal every time.
I use a homemade fixed blade
Whats the story behind that?
