Eureka Northern Breeze Canopy
jbonham
It a little pricy but it works great
Work great on a rainy weekend. Gives you enough cover to get the camper with out getting wet.
We don't tend to sue any external poles as they are dog lead catchers which is why we love the NB as you cant just stake down with no guy ropes.
If its bad we tend to pull the NB right over the doors but I do like that set up with the front fly sheet extended.
I would like to get another zip fitted horizontally across the top of one set of mesh doors to make sealing around the CI easier.
We only use the poles when we are drying the flaps. Otherwise we go straight to the ground and stake them out so the water rolls off. We used a strap in the middle to the the hitch triangle to keep the center pull tight. We had no water pooling on the canopy.
