Electrical operation with battery removed
Discussion in 'Electrical & Mechanical Issues' started by Jim Carter, Sep 5, 2018.
  1. Jim Carter
    So in a few weeks I will have to winterize my camper, including removing the battery since I will storing my camper in an unheated storage unit that does not have electricity.
    My question is, If I remove the battery at my home will the lights still function with the camper connected to the TV 7 pin connector so I can drive it to the storage facility?
  2. rotus8
    rotus8 Ranger Donating Member
    I believe that the trailer will work fine with the 7-pin connected and no battery. The one wild card is if you have a battery isolator installed in the trailer. The isolator may be unhappy without the battery but I think it will turn on and be fine. You won't hurt anything so give it a try, but try it early so if it doesn't work you can go to plan B.
  3. Jim Carter
