Curtins
Discussion in 'Custom Additions' started by Jenn, Jun 10, 2024.
  1. Jenn
    Jenn Ranger
    My teardrop (#452) is on its 3rd set of curtains. The first set eventually became separated from the plastic runner that attached to the rails at the top and bottom of the curtin. I tried different fixes but eventually got new curtains from Campinn. Same with the second set and got moldy on the window side. Then it was suggested that I take off the bottom rail. This reduced the pull stress. These eventually just looked worn out so I got a 3rd set. (Thank you Cary for digging through the bin for an older set. The earlier ones were darker.)
    Now with the bottom rail gone I learned how to roll the curtin up and clip or pull up to the side. I use a light weight claw hair clip. The curtin is rarely slid back and forth on that top rail. See pics.
  2. Kevin
    Kevin Ranger
    Great tip, and timely, thanks!
    ...I may need a replacement set on my 2010, and prefer the rollup vs slide over technique, so I dont rip things in my ham handedness...;)
  3. Sweeney
    Sweeney Ranger
    Nice solution. I think I have a few of those in my kit :) I want to find the rails and clips CI uses. Some time in the future, I want to make curtains that are slightly larger (just 2-3 inches to fully cover the openings...and may be add a light proof liner.
    I used to wakt up at 6:30 --- but have been semi-retired for a couple months, then working in a job that I start work at 11 most days....so I can sleep in, except for light leaks.
    Kevin and Jenn like this.
  4. Tour 931
    Tour 931 Ranger
    What a great idea!
    Jenn likes this.
  5. Jenn
    Jenn Ranger
    To darken the door windows I got a 2 pack of black, standard size pillow cases and just clip them to the top of the curtin with the claw clips st night. Then unclip and tuck away when I don't need them. I don't know what you would do on a 560 front windows.
    Kevin likes this.
  6. Lipster
    Lipster Junior Ranger
    Curtains or not, some mornings I wake up grumpy.
    Other mornings, I let her sleep.
  7. skissinger
    Ba-dum-bump
    Kevin likes this.
