Brian Lewis
Just a few questions....
1) Has anyone installed a battery monitor that monitors volts, amps, amp hours and time to go for the battery?
2) Is there space to store a solar panel under the 550 or 560? Maybe a metal rack could be welded to the underside of the frame where your large solar panel could be stored. Is there space? Can the panel be tucked somewhere in the frame?
3) Anyone spray an undercoating on the bottom of a trailer? Is it varnished plywood on the underside? What about something like the undercoating used on a car?
4) I read somewhere about linking the two water tanks together and using a bucket for the grey water. What are the pros and cons of this approach? (I can think of several, but would like your thoughts. Is the current 8 gallons for drinking water problem?
5) Is there a way of adding a "sight gauges" to the water tanks?
6) I would like feed back from someone who has opted for the parking brake option. How do they like that option? I know that some folks think it is a lot of money to do what a couple of blocks can do. How do folks feel that have this option? Is there a way of locking the handle into the "lock position" to deter thief?
Your input would be welcomed. I numbered the questions so you could answer by number if that helps...thanks. Signed, Tearfully Yours
