2026 Camping Gear
Sweeney
Administrator
We're rapidly approaching camping season! That means two things:
1] Finding camping spots
2] Buying more gear!
What is the latest gadget or item you've loaded into your vehicle, or added to your home kit to make camping easier?
------ I'll start! -----
I recently got my hands on a Mr. Heater Fuel Keg system and a couple kegs. I did not buy this specifically for camping, but keeping my mr heater running in my van to keep me warm in the field. If you use 1lb tanks this system is a real time and money saver. The Big Buddy heater will suck through 2 propane tanks in a couple of hours. I don't use it inside the camper, but it keep sy side room toasty, and my side room toasty.
The process to fill is simple and safe - I've filled 6 or 8 cans so far. The fill kit is around $25 and each keg is $18 -- I've got 4 kegs -- 2 in the heater, 2 in reserve. So say $100. The best price is $5 each on the kegs, so I'm 1/3 of the way to return on investment in 2 months. The other part is, I'm not throwing away steel after 1 use...becuase lets face it there's no way to really recycle the single use cans.
The cost of a refill is about $1.30 for the propane assuming you use the horrible blue-rhino exchanges. Less if you actaully fill your own 20 pounder.
I'm really impressed with the system. The only hard part is you need to plan to fill when it isn't 0 degrees! I had to put my 20lb cylender in a heated garage to get it warm enough, then stand outside for 10 minutes while I actually filled my kegs -- lack of planning on my part though has nothing to do with their product.
My most recent purchase (over a year ago) was for boondocking in the shoulder season when it’s colder. Of course Amazon doesn’t have the exact one anymore, but search Amazon for ‘heated sleeping bag liner’. That, plus multiple (charged) usb battery packs and it warms up the bed nicely when you don’t have an electric site / boondocking. I don’t have a furnace in my 550. Usually one battery pack lasts the night on the low setting. I have 3 battery packs, because I usually do long weekends, so that gets me thru a long weekend, toasty sleeping.
Of course, also multiple wool blankets and/or other blankets as well to retain that heat.
Are you using them in a sleeping bag or a DC powered mattress pad? I am finding that I don't sleep well wiht a mattress pad left on, what I have started doing is pre-warming things....then usually waking up mid night and having to turn it back on...'high' to just bump the temperature. If I leave it on low (comfortable temperature) I just dont' get the rest.
I can't help but wonder if there is something more to the sensitivity to electricity....DC may not be as bad if it is. Dunno.
The problem with number two buying more gear is Reconfiguration!
The Black Friday deals I purchased… solar panels and battery will take some reconfiguration of the packing. I have a plan but you never know till you put it in motion
I don’t have a sleeping bag, I toss and turn a lot.
My layers when around 32 F (or less)
Lowest layer: wool mattress topper
Flannel Fitted sheet
Heated sleeping bag liner, with battery packs, lowest setting, tucked along my side, with outer side facing the door, warm side facing me.
(Me, probably with a hat on too)
Flannel blanket
Heavy wool blanket.
Top most layer: winter weight down comforter (to retain any heat that may have escaped the other layers.
If it’s between say, 45-60F, I won’t need the heated sleeping bag liner, and only one or two of the top layers.
For comparison, in the summer it is…
Still wool mattress topper.
Cotton fitted sheet
(Me)
Summer weight down comforter.
I am the kind of person that needs some kind of weight on me while sleeping. Even just a single sheet isn’t enough for me.
I also have froli system under the factory mattress, super comfy.
Edit: I don’t remember anymore where I got the wool mattress topper, it was at least 5+ years ago, but it is this style https://a.co/d/02gn1Tou , that isn’t a specific recommendation, just wanted people who might be interested to know what type of matress topper I use. I primarily camped in Wisconsin / Illinois / Iowa, so it is usually cooler weather I plan for. The wool topper comes inside all winter and airs out in the storage room, it does not get stored away or compressed, so that helps I believe in maintaining loft.
Im interested in the heated sleeping bag liner but can't get Big A to fire up so will search that later.
This could launch in to, or maybe already has , a conversation about sleeping in the cold. When we were having minus 20 degree days in Wisconsin this winter and concerned about power loss in the houses, we were having conversations about how to stay warm. And I have that pretty dialed in from the teardrop.
Diver Bob, Im a big fan of hot water bottles at feet and core.
Sherry, I also have a wool mattress topper and love it. For me I have to warm up under neath the best and then the rest works better.
Sweeney, I dont much like sleeping with an elec grid going around me either. Just feels creepy. I'll warm the bed and then turn it off but I dont want it running.
One of my best and very long lasting pieces of gear has been a Northface full size sleeping bag. I keep looking a new ones but havent pulled the lever to update that. It really holds the heat in and then I can pile up warmies on top. I have a 20 degree rectangle down bag with a hood. When it's opened flat over top, I use the hood as a tent over my head to hold in heat but still have fresh air.
So, still trying to get to see what that heated liner is! Thanks, Sherry!
I blinked while shopping at REI and suddenly noticed I owned this Nemo Stargazer Evo-X. Not the lightest or cheapest but on the former, I figure it's for camp, not backpacking. And it is absolutely GLORIOUS to sit in. Looks weird, but super well designed and has lifetime warranty. (I'm a sucker for different, innovative design takes.) This one won out on a massive chair bakeoff on YouTube's Outdoor Empire channel.
I've known people who claimed sensitivity to it, and kind of took the view that it probably was more psychological that physical. But I recognized the pattern in my personal sleep hygiene --- so who knows. Maybe theres something to it.
I"m a sucker for a lifetime warranty - I have to replace both of my chairs this year. We paid not quite that much for ours, and they lasted 3 years...and thats good! Most barely make it through a season!
We have 2 stargazer chairs. One chair had a hub break and it was replaced. Hopefully the new design is easier to put the back support rods in. My wife gets frustrated every time she tries to setup the chairs. Most comfortable camp chairs, especially with a stool for my feet...
I guess there are two styles -- the original which is more complicated to deploy but lighter and more fit for backpacking. The newer one is certainly heavier but also simpler to deploy. Their lifetime warranty is legit. (Your point about the stool is dead-on. I'm going to get one (though a camp box or whatever will suffice in a pinch)
I keep looking at kermit chairs --- the only trouble is they sit 'high and straight' -- I wish they made one that was more laid back like a typical camp chair.
The stargazer looks comfortable -- but it also looks like its kind of 'big' on the broken down size...or am I just not seeing the 'efficient' design?
I would not take it backpacking! I have a version 1 and a version 2 and it is no bigger than any other camp chair folded up. I do not know the size of the newest version but I do not think it will be much different in size folded up. One of my complaints is the bag could be a little bigger so it is easier to put in the bag.
You'd have to really sit in one at REI or someplace first. They are comfy but the fit and design is just plain different. And as you are taller than me (6-1), I'd downplay the "lie back and recline" aspect because you head would likely be higher than the little head rest.
They are about 14-15 pounds and decent sized bag (which is super high quality). I wouldn't want to tote it from camp down a long way to a river spot or whatever. But for just being your main chair in camp, excellent.
Agreed, the Kermit Chair is very cool and high quality, but definitely not a backpacking chair. We bought one from Kermit and the second from the individual who took over from Kermit. My recommendation for a backpacking chair would be a Heloix. We prefer the ones with a higher back and lightly padded headrest.
I picked up one of these kits a while back, made by a company called Full Windsor. In my opinion they are stupidly expensive to buy at full price ($495). Even at a deep 40% discount they often run it's still expensive, IMO. However, they show up from time to time on eBay for about $100 and I pulled the trigger on one.
Obviously, the big draw is the magnetic tabs that hold the set together cleanly and compactly. The salad plates and dinner plates double as lids for the bowls and larger bowls. The cutlery seems strong and is holding up nicely so far. Anyway, it's nice to have something quality and compact that fits into a nice storage bag and everything has its place. Something I have mixed feelings about is that the stainless is single walled. It's definitely thick enough to be sturdy but, because it's single walled, it transfers heat from your hot food about as well as a piece of stainless steel cookware. On a table it's not really an issue, but put some soup or chili in one of the bowls and the only way to hold it in your hands is by the tabbed edges. Also, everything is recommended as hand wash only. Other than that, it's a handy set. I just wouldn't recommend this at full price or, sadly, even at their regular discount of 40% off.
I'm not much into the backpacking - I just want something in camp to sit around a campfire. My 'day job' is stupid fast - I'm constantly up and down ladders, or crouching on the floor, or fitting into storage bays into positions that would make a Cirque performer cringe. When I take a break from it, I just want to chill and let the muscles relax. The kermits may be too 'straight backed' -- not sure.
I guess you won't be ordering the optional dishwasher for your camp-inn now that you have your hand wash only dishes then.;)
Thats some nice gear...
matches the CampInn look...
At a killer price...
