No More Yellow Drain Caps!
Discussion in 'Custom Additions' started by Randy, Feb 8, 2020.
  1. Randy
    Randy Ranger Donating Member
    Replaced them with 3/4 inch threaded ball valves
  2. Jim Carter
    Looks handy!
  3. AlCat
    To an untrained observer, that looks like a bad use for that sort of valve. Seems like it would be pretty easy to drive over something that would pull that valve open......Maybe not an issue for the grey water tank, but I'd hate to arrive at a campsite with an empty clean water tank.
    I apologize for being Donny Downer. (and I submit that I'm no expert at such things)
    LisaNKevin likes this.
  4. Randy
    Good call out Al. I wonder. My thinking is that it is no lower than the stabilizer jacks. I suppose if I did a lot of off-road stuff it might be a concern. But thanks, going to crawl under with that in mind and have another look. The valve also takes quite a bit of force to open. Pretty tight. Also, it open by pushing to the front.
    Ken & Peggy likes this.
  5. hiadventurer
    hiadventurer Junior Ranger
    Is there enough room to rotate entire valve, turn handle over? Basically putting handle on top??? just a thought..
    Chuckwagon likes this.
  6. Randy
    Great idea but nope, not enough clearance. I really think it will be fine as the handle is above the leveling jacks. It also opens by pushing the handle towards the front of the camper so unlikely it would open by hitting something. Really like it, I was famous for misplacing the yellow caps! :)
  7. AlCat
    I like it, too, and I bet it will work just fine.
    Randy likes this.
  8. Jim & Selma
    Jim & Selma Novice
    Hello... My first post on this forum. I just solved this situation this week at Farm&Fleet for less than $5.
    I can't wait to "hit the road" with this upgrade:
    No more corn kernel problems. Full 5/8" bore.
    Positive on/off.
    Plenty of road clearance, as you were discussing.
    It's even a gray/grey color! Jim
  9. Lipster
    Lipster Junior Ranger
    Jim, is there a Gilmour part number?
  10. Lipster
    Jim, this valve just screw on the outlet of the tank, I'm assuming. Is it like a garden hose, with a rubber gasket/ORing?
  11. Jim & Selma
    Jim & Selma Novice
    Doesn't seem to have a number, but just check your local hardware store in the garden hose fittings.
    This Gilmour is the best one I found.
    The other thing we've found is when you stay put camping, you will have to add water. Then, of course you eventually smell gray water as it burps out the vents in the tank. We drain off a few gallons into a milk jug and go dump it in the ocean or whatever is convenient.
    Adding water: collapsible water jug or collapsible 50' hose. Pictures below.
    Hope this helps. Jim
    Eve Crowley likes this.
  12. Randy
    Been working great, no clearance issues.
  13. Eve Crowley
    Eve Crowley Newbie
    Brilliant! We are newbies and after just four trips realized that we needed to figure out a system for this!
  14. Lipster
  15. Ken & Peggy
    Ours are arriving tomorrow from that same small company - I hope they can handle the increased volume (pardon the pun). Thanks Jim & Selma for the great suggestion.
  16. klint74
    klint74 Novice Donating Member
    I was so excited I ordered one too......I forgot that I sold my camper 2 days ago.
  17. Lipster
    Oh, you have it bad...
  18. Lipster
    Small, well known mail order company.
    Montgomery Ward?
  19. Ken & Peggy
    The other one...
  20. Lipster
    Fingerhut?
    W W Grainger?
    Etsy?
